Serge Dal Farra, Lubmarine Marketing Manager, explains 3 steps of effective engine lubrication including right engine oil selection, proper monitoring strategy and not forgetting the human element and engineer support.
The development of low sulfur fuels through the introduction of IMO2020 has been the most significant change to the way in which the global fleet has been powered since the introduction of the diesel engines in the maritime industry a little over 100 years ago.
Whilst the use of low sulfur fuels has clear benefits on emissions reductions, what has been proven is that challenges around fuel quality -especially early 2020- have brought real issues for modern 2-stroke marine engines.
For not only are these engines sensitive to corrosion but they also face an increased risk of engine deposit build up – potentially leading to problems including notably ring pack damage.
What is without question is that selecting the right cylinder oil in tandem with a properly managed Monitoring Programme in the post IMO2020 landscape has never been more important than it is today.
Selecting the Right Lubricant
Here at Lubmarine we have developed a range of tailored lubrication formulations designed specifically to manage today’s modern marine engines, for all IMO2020 compliant fuels including LNG.
Our premium product Talusia Universal is a fully OEM approved cylinder oil with a patented chemistry, proven with over 125,000,000 successful operating hours.
Tests show that Talusia Universal demonstrates a significant cleaning ability (detergency) and provides higher residual BN, enabling ship operators to optimize their feed rate and maintain the lube oil into the safe limits determined by the OEM’s.
Additionally, Talusia Universal has been approved by WinGD as a “Dual Fuel validated” product, one of the few cylinder oils on the market to have obtained this achievement.
The latest entry in the Lubmarine Talusia range of cylinder lubricant is Talusia HD 40 for which MAN ES has granted a NOL Category II meaning this product has excellent overall performance with a special focus on cleaning ability and is applicable for all engines types and recommended for MAN B&W two-stroke engines Mark 9 and higher, providing operators with increased safety margins for very demanding engines.
“We are delighted with this latest recognition from MAN ES and we believe this new generation of cylinder lubricant will provide added safety margin for the ship operators,” said Stuart Fuller, Lubmarine’s Market Liaison & Product Manager responsible for MAN ES.
Taking a Multi-Layered Approach to Engine Cleanliness
Using the right lubricant in the right amount to deliver optimum performance and effective engine cleanliness is just one piece in the puzzle.
Rising to the challenge requires an understanding of the multiple operating parameters of the engine, combined with smart engine monitoring and drain oil analysis and interpretation – something that can only be achieved with the support of a lubricant specialist.
By carefully and regularly monitoring lubricant and vessel machinery condition, ship owners together with their oil supplier can proactively detect and react to any abnormalities.
All OEM guidelines recommend careful engine monitoring and a sophisticated intelligence-led approach allowing for the most prudent management of two stroke marine engines.
Implementing A Robust Monitoring Programme
Implementing an effective Drain Oil Analysis Programme is a simple, reliable and a proven way of helping optimize operations through lubricant consumption and component wear analysis.
LubInsight Neo: Tapping into the Benefits of A New Range of Inter-connected Onboard Digital Analysis Services
We are now taking this approach to new and data-focused levels, with the launch of a new range of fully digitalized, interconnected global on-board lubricant sampling and testing services.
Operators on board are guided through easy to follow, step-by-step on screen instructions when carrying out drain oil analysis without the need for specialist training, with the highly accurate test results uploaded onto the customers’ dedicated Lubmarine portal.
Not only do the new services – LubInsight Neo – enable vessel operators and owners to upgrade their onboard testing laboratory facilities, but they also deliver real-time interconnectivity between crews on the vessel, all on shore operations, owners, operators and global teams involved in the running and maintenance of the vessel.
The Human Element – Specialist Knowledge and Interpretation
The third layer in achieving optimum engine performance including its cleanliness profile is to enlist the support of highly experienced engineers to assist with lubrication optimization and any lubrication issues vessel operators might be experiencing.
This level of support can include:
• Ship engine inspections and trouble-shooting
• Lubrication survey and technical investigations
• Shipyard and switchover support
• Crew and onshore teams trainings from lubrication basics to high level lubrication strategies
Conclusion
There is no single solution to achieving the benefits that LOFR optimization can deliver. It takes a multilayered approach, utilizing the tools and knowledge with the support of a technical team and the infrastructure of a specialist lubricant manufacturer with the range of services available to support vessel operators.
NexusWave, the fully managed, bonded connectivity service from Inmarsat Maritime, a Viasat company, has been awarded Cyber Security Type Approval by ClassNK. The certification follows ClassNK’s assessment of its onboard...
In an open letter to the industry, ABS has set out a measured and data-driven approach to support the development of an effective global framework for maritime decarbonization. Titled, The ABS...
Wallem Group, a leading global maritime partner, has released details of an incident in May when a ship under its management rescued two Filipino fishermen from their sinking boat. The...
June 8, 2026
— just like 105,056 professionals
— trusted by our 105,056 members
