Anchor and Mooring Gear – A History
John Konrad
July 21, 2010
Chief Mate Andre van Schoonhoven of the new cruise ship Eurodam gives us the history of classifying anchors. He writes;
Hawsepipe of Newbuild Crewship without anchor
Traditionally ships were anchored using large hemp hawsers called cables. In 1836 the use of iron chains had become so common in the English merchant service and their superiority so well recognized, that the underwriters ceased to charge a higher insurance rate for vessels using iron chain. In 1840 side welding of chain was introduced in England, and from that time English chains of 1-7/8 inches and larger have been side welded.
Lloyd’s Register of Shipping augmented its rules in 1846 so that thereafter all chains of classed vessels were tested and stamped on each end to indicate load capacity. In 1853 Lloyd’s rules made it mandatory that, before a vessel could be classed, the test of the chain cable had to be certified, and in 1858 Lloyd’s issued rules regarding the length and size of chain cable. Lloyd’s progressively stiffened their rules regarding methods of manufacture and testing, resulting in the Anchors and Chain Cables Act of 1899, which with only a few amendments is still the basis of present-day testing procedures.
He also provides a timeline of anchor chain developments. Here’s an excerpt;
Ship's Spill Pipe Seen From Chain Locker 1808: Wrought-iron cables are first recorded.
1834: Lloyd’s Register rules state the length of cable to be supplied, they call for a reduced length for iron cables compared to hemp cables at a 6:7 ratio.
1846: Rules specify that cable must have been tested and have the test load stamped on it.
1856: The rules state that the length and condition of chain cables were to be ascertained by removal from the locker at each special survey.
1890: Lloyd’s Register rules sets a table of minimum weights for cables.
Andre continues with details on how a Lloyd’s List determined the Eurodam anchor’s size as well as the number of shots of chain needed.
Read the full article HERE or more about ship anchors HERE.
NOTE: This article was originally published in Jan. 2008
