Note: With the spring boating season upon us, the U.S. Coast Guard warned today that although the air temperatures are warmer, the water is still cold and presents a significant danger to those looking to cool off. This article was first published to gCaptain.com in 2010, and we are reposting today (April 12, 2013) to help you stay safe while out on the water this season. A link to a follow-up article, titled “The Truth About Cold Water Recovery”, can be found at the bottom of this page.
Image (c) Shutterstock
By Mario Vittone
I’m going to come right out and tell you something that almost no one in the maritime industry understands. That includes mariners, executives, managers, insurers, dock workers, for certain – fisherman, and even many (most) rescue professionals:
It is impossible to die from hypothermia in cold water unless you are wearing flotation, because without flotation – you won’t live long enough to become hypothermic.
Despite the research, the experience, and all the data, I still hear “experts” – touting as wisdom – completely false information about cold water and what happens to people who get in it. With another season of really cold water approaching, I feel compelled to get these points across in a way that will change the way mariners behave out there on (or near) the water.
What follows is the truth about cold water and cold water immersion. I know that you think you know all there is to know about hypothermia already (and maybe you do), but read ahead and see if you aren’t surprised by something.
When the water is cold (say under 50 degrees F) there are significant physiological reactions that occur, in order, almost always.
You Can’t Breath:
The first is phase of cold water immersion is called the cold shock response: It is a stage of increased heart rate and blood pressure, uncontrolled gasping, and sometimes uncontrolled movement. Lasting anywhere from 30 seconds to a couple of minutes depending on a number of factors, the cold shock response can be deadly all by itself. In fact, of all the people who die in cold water, it is estimated that 20% die in the first two minutes. They drown, they panic, they take on water in that first uncontrolled gasp, if they have heart problems – the cold shock may trigger a heart attack. Surviving this stage is about getting your breathing under control, realizing that the stage will pass, and staying calm.
You Can’t Swim:
One of the primary reasons given by recreational boaters when asked why they don’t wear a life jacket, is that they can swim. Listen up, Tarzan; I swam for a living for the better part of my adult life, and when the water is cold – none of us can swim for very long. The second stage of cold water immersion is called cold incapacitation. lacking adequate insulation your body will make its own. Long before your core temperature drops a degree, the veins in your extremities (those things you swim with) will constrict,  you will lose your ability control your hands, and the muscles in your arms and legs will just flat out quit working well enough to keep you above water. Without some form of flotation, and in not more than 30 minutes, the best swimmer among us will drown – definitely – no way around it. Without ever experiencing a drop in core temperature (at all) over 50% of the people who die in cold water, die from drowning perpetuated by cold incapacitation.
You Last Longer than You Think:
If you have ever heard the phrase, “That water is so cold, you will die from hypothermia within ten minutes.” then you have been lied to about hypothermia. For that matter you can replace ten minutes with twenty, or thirty, or even an hour, and you’ve still been lied to. In most cases, in water of say 40 degrees (all variables to one side), it typically takes a full hour to approach unconsciousness from hypothermia, the third stage of cold water immersion.  But remember, you must be wearing flotation to get this far.
We are all different in this regard, but I once spent an hour in 44 degree water wearing street clothes and my core temperature was only down by less than two degrees (I was not clinically hypothermic). It was uncomfortable to be sure, and I wouldn’t recommend finding your own limit, but it probably would have taken another hour to lose consciousness, and an hour after that to cool my core to the point of no return. The bodies efforts to keep the core warm – vasoconstriction and shivering – are surprisingly effective. The shivering and blood shunting to the core are so effective, that twenty minutes after jumping in (twice the “you’ll be dead in ten minutes” time), I had a fever of 100.2.
Rescue Professionals Think You Live Longer:
There is a good side to the misconceptions about hypothermia. Should you ever be in the water in need of rescue, you can be certain that the Coast Guard is going to give you the benefit of every possible doubt. When developing search criteria – search and rescue coordinators use something called the Cold Exposure Survival Model (CESM): It is a program wherein they enter all the available data about the victim (age, weight, estimated body fat, clothing, etc.) and about the environment (water temp, sea state, air temp, wind) and the software spits them out a number that represents the longest possible time you can survive under those conditions. I plugged my own information into it once and it said I could survive for over 4 hours in 38 degree water wearing nothing but a t-shirt and jeans and no flotation. I can tell you from experience that the CESM is full of it – I’d give me 35 minutes tops – but the error is comforting. If the program that determines how long I might live is going to be wrong – I want it to be wrong in that direction.
Out of the Water is Not Out of Trouble:
I lost count of the number of survivors I annoyed in the back of the helicopter because I wouldn’t let them move.  I had a rule – if they came from a cold water environment – they laid down and stayed down until the doctors in the E.R. said they could stand.  It didn’t matter to me how good they felt or how warm they thought they were.  Because the final killer of cold water immersion is post-rescue collapse.  Hypothermia does things besides making everything colder.  Victims are physiologically different for awhile.  One of the things that changes is called heart-rate variability.  The hearts ability to speed up and slow down has been effected.  Getting up and moving around requires your heart to pump more blood, being upright and out of the water is also taxing, then any number of other factors collide and the heart starts to flutter instead of pump – and down you go.  Victims of immersion hypothermia are two things; lucky to be alive, and fragile.  Until everything is warmed back up – out of the water and dry is good enough – mobility comes later.
Did You Learn Anything?:
If you did, then hopefully you’ll use it to make good decisions when it comes to being safe on and around cold water; good decisions like these:
  1. When working on deck, wear flotation.  This includes, especially, all fisherman in Alaska.  I couldn’t find more recent research, but the 31 Alaskan “fell overboard” casualties in 2005 died from drowning, not cold water.  Not one of them was wearing flotation.  Many couldn’t stay above water long enough for their own boats to make a turn and pick them up…..over a life jacket.
  2. If you witness a man overboard – getting the life ring directly to them is critical (vital – step one – must do it).  Make certain that all-important piece of safety gear is not just on your vessel, but readily available and not tied to the cradle.
  3. When working on deck – wear flotation.  I said that already? Well, when I quit reading search reports that end with “experienced” mariners dying because they thought they understood cold water – I’ll come up with better advice.
For more advice about how to handle an accidental immersion into cold water – please watch Cold Water Boot Camp – it is one of the best 10 minutes on immersion hypothermia ever produced.  For even more advice, ask me a question on the discussion boards.
YouTube Preview Image
Don’t Miss Part 2 Of This Article: The Truth About Cold Water Recovery
See Also: Drowning Doesn’t Look Like Drowning
Comment On Facebook
Article Comments
6 Responses to The Truth About Cold Water
  1. avatar Keena says:
    I know this well. Though it did not happen in open water, but rather a indoor swimming pool. I had been SCUBA diving for a few months. I was really enjoying it and doing very well. So well infact that my instructors and friends were trying to convince me to take the next steps to become a rescue and recovery diver. I had been a lifeguard for over 5 years so it did seem like a logical step. I felt extrememly comfortable in the water, had taught basic water survival classes to kids. You know, loose the shoes use your clothing as floatation etc. So I take SCUBA as a class for credit….read here an easy A and stress relief for a hard academic semester. It’s finals time and our regular pool has been drained for repairs so we are borrowing the Campus Recreation pool….which is having heater issues and it is December. The water was still 70 degrees, but I got knocked off my star student pedestal faster than the automatic gasp response. At the time I was 5’4 and weighted about 105lbs. We were practicing simple ditch and dawn, no other factors or simulations. Just tank, fins, and mask in one hand and your regulator in the other. I choked 3 times and still kept trying. Just before the 4th attempt, the instructor realized I was shaking so hard that I could barely square away my gear.
    Fast forward to about 1 year later, I had taken a job with the Navy MWR in Japan. I was swimming just a short 500 meter swim at dusk in a pool that’s temp was probably low to mid 70s with an airtemp of about the same. About 100 meters in I start to feel as if I couldn’t breath. I switched from free style to breast stroke hoping that the change of pace would get me over the hump, but by the time I got to the pool edge again I was almost hyperventilating. I got out they wrapped me in towels and I shook like crazy for the rest of the day. It’s never happend since and that was almost 8 years ago.
  2. avatar tom says:
    Good article. Small but important typo. I think the word “not” is missing in the sentence “Until everything is warmed back up – out of the water and dry is good enough – mobility comes later.” Should be “Until everything is warmed back up – out of the water and dry is *not* good enough – mobility comes later.
    • No Tom, that isn’t a typo. It came after the section on the importance of not moving around – so “out of the water and dry is good enough” You can worry about moving around later – after you have warmed up.
  3. avatar dennis says:
    thank you very much for this important PSA!
  4. avatar wp says:
    Thanks for the article. I’ve never understood why any boater wouldn’t wear a PFD when out on the water…
    One question…I am curious as to what data supports your declaration:
    “Without some form of flotation, and in not more than 30 minutes, the best swimmer among us will drown – definitely – no way around it.”
    Not trying to create an argument, but I think the 30 minute limit may be incorrect. I say this because I have participated in several open water swim races (no wet suit, no flotation), where the water temperature was in the mid-50′s. Hundreds of people in these races and some include multiple 30-minute legs (Trans-Tahoe Relay) and/or a course that takes some individuals at least 30-minutes to finish the race (Santa Cruz Roughwater Swim; Golden Gate Crossing).
    Thanks in advance for your response.
  5. [...] het nut van een reddingsvest! Overigens: 45°F is 7,2°C KIJKEN! (Het bijbehorende artikel staat HIER) This entry was posted in Alle categorieën, kajakken and tagged kajakken, koud, [...]
Leave a Reply
Your email address will not be published. Required fields are marked *
You may use these HTML tags and attributes: <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <del datetime=""> <em> <i> <q cite=""> <strike> <strong>
